Browse Forums Lighting + Lighting Design 1 May 21, 2012 1:02 pm ***LED DOWNLIGHTS*** Hi All, Has anyone recently (This Year 2012) done colour and electrical selection and know what options are given regarding down lights? I'm assuming due to the new BCA that they have to be primarily LED??? Thanks!! Re: Carlisle HomesVIC LED Downlight Options and Cost 3May 23, 2012 4:07 pm Under the new BCA guides your lights can't use any more than 5 watts of power per square metre. For an easy example, in a 10 square metre house you could only have 1 traditional 50watt halogen downlight, however you could install 5 10watt LEDs (LEDs that can be retrofitted after halogens are 10 watts). In a new build however I would install fully integrated LED downlights. these use about 16 watts, but provide over 900 lumens of light (brightness), while halogens provide 720lm. With the extra brightness provided by intergrated LEDs, you will easily comply. The integrated fittings seem to work a little better than retrofits. Hope that somewhat helps. Re: Carlisle HomesVIC LED Downlight Options and Cost 4May 24, 2012 8:40 am We have found that big builders are still opting for the cheapest solution that will comply, we have mostly seen LED gu10 bulbs being used to meet code. To get a decent fitting in your roof will cost over $150 per fitting installed (supplied by builder) from our experience. We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37559 Ha all, I am now about half way (maybe a bit more) through my build with Carlisle Homes - double-storey knockdown/rebuild project. So I am now doing my due diligence and… 0 3825 |
