Browse Forums Lighting + Lighting Design Re: Ambient Lighting under bathroom vanity 5Oct 21, 2011 8:42 am Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Re: Ambient Lighting under bathroom vanity 6Oct 21, 2011 12:11 pm You should be able to get an even affect with LED strip, the strip needs to be using 3528, 3020 chips or a lens to achieve this. As a rule of thumb for brightness: 5watt/m for dark environments (pub/club) 10watt/m for daytime features (kitchen/bathroom) 20watt/m for maximum brightness http://img219.imageshack.us/img219/450/bookcase.jpg Assuming a wall plate is nearby you can install a dimming pot to control brightness if its too much. It can also be waterproof if your splashing in the bath Transform your bathroom into a sanctuary of calm and sophistication with Hera Bathware's Bathroom Vanity Collection. A standout… 0 13068 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29075 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9101 |
