Browse Forums Lighting + Lighting Design 1 Aug 25, 2011 9:25 am So, I've found an LED GU10 globe that I'm happy with "lightwise". However - it's slightly longer than my normal GU10 globes, so we can't fit the gimbal ring back on! The globe almost extends down to the level of the ceiling (whereas the previous ones are approx 1cm higher than ceiling and the gimbal edge goes up to meet it, if that makes any sense). Is it possible to buy 'gimbal rings' that would fit on our existing (10yo) fittings, that have a flat/flush with ceiling profile and might fit with these led lights? Thanks. Re: Gimbals and LED lights 3Jul 14, 2012 1:53 pm We are buying the lamps and the fitting all in one from the same supplier...that way they should all work together. Re: Gimbals and LED lights 4Jul 16, 2012 5:59 pm The only way to fix that is get an 'open' gimbal that doesnt have a height restraint, there are plenty to choose from. Finding the same style might be tougher. So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23019 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10031 |
