Browse Forums Lighting + Lighting Design Re: Do you buy your lighting online? 6Jun 22, 2011 2:21 pm Site Start: 10th September, 2010 PCI : Friday 27th January, 2011. Handover: 3rd February, 2011 Build Thread: viewtopic.php?f=31&t=37677 Re: Do you buy your lighting online? 11Apr 30, 2013 9:49 am My favourite lighting shop: http://online-lighting.com.au Re: Do you buy your lighting online? 15Apr 04, 2018 6:17 pm mattsmith Hey there, I always buy my lights from http://www.lightingstyle.com. I have only recently discovered them. 😂😂😂 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8814 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8572 |
