Browse Forums Lighting + Lighting Design 1 Apr 11, 2011 2:14 pm I am concerned we don't have enough.
the kitchen/dining/living space. Kitchen has a bulkhead over it with 3 over the island and 2 in the kitchen space - should be enough Family & Dining have a total of 6, 4 over living 2 over dining. Family & Dining is 5.5m wide & 8.1m (10.6 including kitchen) Here is the plan - do I need to add more? http://i79.photobucket.com/albums/j132/MEV09/HousePlans.png Re: Do I have enough CFL's in this space??? 2Apr 11, 2011 3:32 pm What I have done is have the downlights 2 metres apart and 1 metre of the wall. That is, one light for every 4 square meters. I have then used 13 W CFL lights. The lighting is adequate for most applications, but things like kitchen could do with more. Like you I have some pendent lights to supplement the lighting. End result, all good. Demolition August 2009, Construction Started September 2009, Completed December 2010 Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 5381 As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 572 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9970 |
