Browse Forums Lighting + Lighting Design 1 Mar 27, 2011 12:16 pm HI My lightshop suggested instead of LED everywhere to put CFL in the general living areas and The brightgreen led in the funcitonal specific areas as they have more task /brighter specific light - does this sound right? Any thoughts many thanks renobeginner Re: CFL & LED is one better for task lighting & one for gene 2Mar 29, 2011 8:35 am CFL's are a much wider angle, so if you like or are used to halogens go with a quality LED as they can replicate similar beam angles angles.
The LED or CFL choice is very much personal so I would be trying to see both before making a decision. Re: CFL & LED is one better for task lighting & one for gene 3Mar 29, 2011 8:01 pm We have the brightgreens in both living and task areas and are happy with them. Mind you we have never had downlights so don't really have anything to compare to. You should check your detail drawings, it may show downpipe within brick pier. 14 14022 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7557 |
