Browse Forums Lighting + Lighting Design 1 Mar 14, 2011 2:52 pm Hi. Just wondering if anyone can recommend a helpful lighting store in Perth. We're owner builders and are trying to finalise our electrical plan and we're a bit stumped as to how many downlights we'll need in our passages and kitchen, what sort of downlights to get, where to put then (edges of passage or middle?). We're in the eastern suburbs. Thanks! Our owner-builder journey - viewtopic.php?f=38&t=45187 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28821 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8824 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8588 |
