Need advice - Downlight choices with Porter Davis (PD)
The following are my possible choices as I see it:
1) All downlights to be fitted by builder [Not preferred. Too expensive. Beyond my budget.]
2) Junction box in roof ready for post completion install of all downlights by electrician
3) Standard Battons fitted by builder at all desired downlight positions then change to draft-proof downlights myself [Will this scenario satisfy Electrical certification requirements? Is this considered same as simply changing a DIY light fitting (i.e. Batton to Chandelier, etc.)]
4) Is there another better option I have not thought of?
I am obviously aiming at spending the least amount possible.
I would appreciate advice from others whom have followed similar solutions.
Thanks.
James
Option 3 doesn't sound feasible as you would still need to disconnect the batten fittings which means playing around with 240V which needs an electrician.
James I would say option 2 would be the best if you can ask them to fit power outlets in the roof rather than junction boxes, then you can cut holes and plug in any down light you buy.
This sounds very interesting......
Do all downlights come with power point plugs?
We just signed with PD and will be starting in Sept. Will be having our Color, Electrical, and Tiles appointments next week.
Did you manage to get PD to install power outlets in the roof as suggested by LEDenthusiast?
Thanks
Kenneth
Im an electrician by trade, and have sold hundreds of downlights to customers like yourselves looking to save on the installation of downlights.
I would suggest the electrician install what is known as a 413 (female plug in the roof) and you could do a DIY (if you a capable) or call an electrician (shouldnt be longer than a day if all plugs and locations are known) to install the lights for you.
Not all downlights come with a flex and plug, but can be purchased for about $3.50 each and attached to every downlight. We have these in our store and all comply with Australian Standards.
If you have any further questions, please don't hesitate to ask.
3
Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report
24/10/2023
2
Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor
29/10/2023
2
XCEM Alpha flooring seems to relatively new and I could not found any reviews. Have you or someone you know have used it and would recommend over other subfloor options?…
