Browse Forums Lighting + Lighting Design 1 Dec 20, 2007 1:30 pm Hi All
We are jsut finalising our lighting plan with our builders. I was wonder what type of external lights should one think of for the outside of house? Should we be looking at putting flood light or just a junction box at the moment? Any thoughts here are apprecaited ! Regards Nonie Building in Western suburb Melbourne Re: External Lighting 2Dec 20, 2007 1:58 pm will you be happy with flood lights after? - if not then no point paying for flood lights now if you are intending to put something else on when you move in - just put a JB on Built Porter Davis "Dromana" 2007. Re: External Lighting 4Dec 23, 2007 6:02 am I guess it depends if you like the look of flood lights, I personally don’t.
I would suggest you go to some lighting stores or on line and check out what lights are available. It won’t make much difference if the JB is lower down the wall. Re: External Lighting 5Dec 24, 2007 12:13 pm How about you do some searching for Garden & Outdoor Architectural Lighting
You'll find there is a lot more on the market now than plain and boring flood lights. Re: External Lighting 7Jan 28, 2008 9:08 am great suggestions I will try them myself too...I´ll let you guys know how this works.. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28804 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8810 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8551 |
