Browse Forums Lighting + Lighting Design 1 Jan 24, 2011 10:17 am Our portico is 2.3mx3m and we are considering putting 4 downlights in there. Do you think that's too many? How big is your portico and what sort of lighting have you got in there? Re: How big is your portico and what sort of lighting is the 3Jan 24, 2011 11:15 am even 1 downlight would be enough - it's just a portico and you only need to be able to see who's at your door... are you having external lights on the portico pillars? Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: How big is your portico and what sort of lighting is the 4Jan 25, 2011 8:56 pm Cheers for that guys Re: How big is your portico and what sort of lighting is the 5Jan 25, 2011 9:10 pm Our portico isn't huge nor tiny. We have a transformer, sensor light which you can also use to time how long it stays on for or you can have it on without the sensor. Re: How big is your portico and what sort of lighting is the 6Jan 25, 2011 10:15 pm Our portico is nearly 6mx2.7 and we have two downlights. They are plenty. They only get used when people are here at night. We have uplights on the pillars and garage that are on a sensor, so there is always plenty of light if people rock up unexpected. Re: How big is your portico and what sort of lighting is the 7Jan 25, 2011 10:36 pm Our house isn't built yet, but our portico will be approx 2.5m x 2.4m. We put one down light and then one light on each pillar (2 pillars), and a fog light on the garage. Building the Porter Davis Sandhurst 33 Our Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=42820&start=20 Does anybody who I can contact to adjust the portico on the ground to relevel the portico and roof? 1 832 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28819 |
