Browse Forums Lighting + Lighting Design Re: DIY light fitting 2Dec 05, 2010 6:33 am diabex i have some electric experience, but not an electrician. Can I install the lighting in my own home by myself? Will I be against law if I DIY the lighting? Re: DIY light fitting 3Dec 06, 2010 10:45 am Also depends on the fittings, as I spotted some the other day that mount to the existing battern holder, and hence don't require you to modify the existing wires. Some people don't have time to do the job right the first time, but seem to have plenty of time to fix their mistakes. Build Thread Re: DIY light fitting 4Dec 06, 2010 11:14 am Richo Also depends on the fittings, as I spotted some the other day that mount to the existing battern holder, and hence don't require you to modify the existing wires. Meant to say that... if you're not altering the wiring you can do whatever you like in terms of hanging lights. But if you're fitting pendants or other light fittings that require you to work with the wiring, you will not be covered if anything goes wrong, as you wont have a compliance certificate (or whatever electricians issues... ) Re: DIY light fitting 5Dec 06, 2010 3:20 pm Hi.... Yes, what everyone else said. We are building the Clarendon Ballina 43 atm and we want to put ALOT of lighting in our new home but the prices are sooooo ridiculous. As my husband is an eletrical technician, it seems so silly to pay anyone else to do the extras. We've found out that anything we do will void our warranty on all electricals. Also we aren't allowed to do ANYTHING until after handover !! Terry & Fi Bought block April 26, 2010 Soil test July 20 Slab down Nov 8 Frame up Nov 19 Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close… 1 4782 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5642 |
