Browse Forums Lighting + Lighting Design Re: Dimmable LED / CCFL Downlights? 21Nov 20, 2010 7:16 am Has anyone purchased the 5x3Watt LED's using CREE XR-E mentioned from LED central? Our "Better Homes Queensland" Cairns Build viewtopic.php?f=31&t=40451 Current stage - 1st builder's clean done. Keys soon. Re: Dimmable LED / CCFL Downlights? 22Nov 20, 2010 7:32 am danrts Has anyone purchased the 5x3Watt LED's using CREE XR-E mentioned from LED central? I did look into LED central but am likely going with a combination of ones from OSRAM from my electrician and also with some from LEDenthusiast on here. Will send you a PM. RF Build: viewtopic.php?f=38&t=34534 Flooring: viewtopic.php?f=7&t=39733 Chat: viewtopic.php?f=36&t=53303 Re: Dimmable LED / CCFL Downlights? 23Nov 20, 2010 10:33 am LEDenthusiast Hi Cheltenham, I am assuming you have placed an order already, did you go with the crompton or Osram? Hi LEDenthusiast, I ordered the Cromptons through my sparky, about the time of my earlier posts. The uncertaintly over delivery dates for Pierlite through cheaper suppliers ruled them out, and I wasn't aware of the Osrams. I'll post some pictures of them when fitted. I did have a sample one that I took to various houses with (cheaper) LED, CFL and Halogen downlights fitted. The light was much warmer and brighter. Re: Dimmable LED / CCFL Downlights? 24Feb 03, 2011 11:11 pm cheltenham3192 LEDenthusiast Hi Cheltenham, I am assuming you have placed an order already, did you go with the crompton or Osram? I'll post some pictures of them when fitted. We have finished our extension and we are delighted with the Crompton LED downlights. They are a warm white and bright. We have blogged our thoughts and pictures now that we have used them for a few days; certainly no regrets! We ended up with them in our open plan living and dining area, and in our ensuite. Just today we have decided to put a dimmer switch on all of them in the living and dining areas (at present it is only on the row above the TV). We will not always want them all at full brightness. Re: Dimmable LED / CCFL Downlights? 25Feb 13, 2011 7:22 am We have now put them all on dimmer switches. Each row has their own dimmer, so our lighting is fully adjustable. |
