Browse Forums Lighting + Lighting Design 1 Aug 04, 2010 4:57 pm hi everyone, I am in the process of building my deck and thought it would be a lovely finish if we put some lights in the deck. However, i was wondering whether anyone knows where I can get some? I had a look at bunnings, is there anywhere else i can get them from? I looked at beacon lighting online and one of those lights cost $50 each, surely i could get these lights cheaper somewhere else? Has anyone put lighting in their deck? Any advice would be greatly appreciated. cheers Idiots are fun, that's why there is one in every village! - Dr. House - Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8813 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8572 |
