Browse Forums Lighting + Lighting Design 1 Jul 22, 2010 9:39 pm I'm currently studying interior design and my current assignment is on Lighting/Electrical for an existing home that I'm "renovating" for my "first clients". I'm interested in the Home Automation stuff but am completely novice at it all....so in basic language how does it connect etc to your lighting, air con, security etc? This "home" that i'm renovating for the assignment will need to be re-wired and I'll need to show an understanding of how the installing a home automation can be done to an existing property. Any advice appreciated. Cheers Just completed DIPLOMA INTERIOR DESIGN!! http://www.thelittleshouse.blogspot.com Check out our progress thread... viewtopic.php?f=38&t=39954&p=596811#p596811 Re: Home Automation Installation Q 2Jul 23, 2010 2:18 pm anyone? Just completed DIPLOMA INTERIOR DESIGN!! http://www.thelittleshouse.blogspot.com Check out our progress thread... viewtopic.php?f=38&t=39954&p=596811#p596811 Re: Home Automation Installation Q 3Jul 26, 2010 10:04 pm Hi Liz, Basic rundown you can get the DIY home automation kits that add onto your existing fixtures as in its a adapter between light socket and globe, and between power point and appliances. They do look primitive like a big timer on the sockets. Or have a electrician install a different system into the house so that none of it can be seen i had it done on our house this way but was kinda $$$ but would be drastically cheaper if house was being built and wired for the first time. Is still pretty cool you can control every light, fan, lamp, tv, in and around your house with one remote tho. Re: Home Automation Installation Q 4Jul 27, 2010 3:18 pm thanks so much! Just completed DIPLOMA INTERIOR DESIGN!! http://www.thelittleshouse.blogspot.com Check out our progress thread... viewtopic.php?f=38&t=39954&p=596811#p596811 Re: Home Automation Installation Q 5Jul 28, 2010 1:08 am Clipsal C- Bus is big here in Aus.. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28804 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5177 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6113 |
