Browse Forums Lighting + Lighting Design Re: Anyone using GU10 CFL downlights? 18Aug 28, 2010 11:58 am The 30 watt versions run alot cooler. With the heat shields, insulation can be placed to a minimum of 25mm. Also use the non-adjustable so u don't have an air gap into roof, like u would have with gimble/adjustable. 0 2020 Broker here - legislation says that every true broker must put the clients best interests before theirs so in theory they must offer you the best options for you on their… 2 46015 Wish you all the best. Once you signed the contract, they will find millions excuses to charge you. And have seen their sites unfinished for a long time. 4 24828 |
