Browse Forums Lighting + Lighting Design 1 Jun 25, 2010 8:20 pm The electrician has just bombarded me with what I want in my new house. I told him to mix the lighting up, that means batten, down lights and other stuff. He also told me the builder has put the posi floor beams closer to each other for strength, this means that normal downlights cannot be fitted because they don't have the wood clearance around them anymore. Great what the hell does that mean I can't have downlights? I have a meals/kitchen room which is 7 X10m yeah I will have 3 pendants hanging over the kitchen counter but what about the rest of the room. Can someone please give me some options. I currently have those fluoro dairy whip bulbs in my rented house and I can't stand this sort of lighting. Electrician said no halogen downlights, led not lighting efficient enough and pricey, so whats left? Re: Lighting for new house 2Jun 25, 2010 8:38 pm something tells me this electriction is being lazy. I am sure it might be a bit harder to centre lights however i think it still should be possible. I cant see your builder putting posi closer than 450 centres. So that will give you about 200mm either side of light. Together with heat can there should be no issues. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8812 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8570 |
