Browse Forums Lighting + Lighting Design 1 May 19, 2010 1:33 pm Hi Everyone! Need some help. I live in an apartment and have a separate kitchen that we recently renovated. Here is the old kitchen which is similar layout to the new one Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The current light fitting is an old ugly fluorescent tube. Now I wanted to put in a nice 4 spotlight fitting in like this But my electrician says that I cannot install one of these as it will create a lot of shadows in the room and when I'm standing at the bench I wont be able to see anything at night. Is this right? If so what do you suggent i put in? I dont want an oyster fitting or anything light that/ Thanks Scott Re: Light for separate kitchen 2May 19, 2010 1:47 pm I had a similiar light in my last kitchen-the only issue I had was when I was working at the bench where the stove was-because the overheads blocked the light. Directly above the cooktop was the rangehood light-it was the benches either side-but that will happen no matter what light it is....what about a couple of undercupboard lights as well? Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Light for separate kitchen 3May 25, 2010 11:55 pm when using a spot type fitting, there will always be an element of shadowing as the globes produce a concentrated light in a specific area. there are 2 ways of overcoming this, as suggested above try incorporate additional under counter lights to assist with the lighting of surfaces alternativelly you could have a 6 light fitting which will give you more options of where you can shine the lights. have a look at this fititng - http://www.ozlighting.com.au/Eglo-Tukon ... P1590.aspx if you can find a fitting that takes 12v lamps then you could use 60 degree lamps which would give you a less focused light and intern less harsh shadows. hope this helps. Thank you so much for your response. I have drawn a pedestrian gate in - for curb appeal, let's see how much costs come in at. I think you're right - if we decide to… 2 6549 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11709 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17378 |
