Browse Forums Lighting + Lighting Design 1 Mar 30, 2010 12:02 pm We are in Perth and would like to hear of any lighting shops you'd recommend. I'm looking in particular for: Pendant Lights - over kitchen bench Exterior lights - we are in coastal area so supposedly need polycarbonate ones (not much choice I don't think) or marine grade steel ie 316 steel. Any ideas? Been to Beacon Lighting and RT Lighting. Love to see photos of anyones pendant lights please. Thanks. Re: Lighting Shops & Pendant Lights - Perth 2Apr 16, 2010 3:34 pm hi Sharon. Nor or SOR? or East? that way someone may know of a great local place. Re: Lighting Shops & Pendant Lights - Perth 3Apr 16, 2010 5:03 pm Hi Sharon, I've been to Vogue and Lighting International in Balcatta, Tillys Light and Lumina Lighting in Scarborough and HS Reflections in Malaga. I liked Tillys and HS the most. Where is RT lighting? Hope this helps, I know how hard is it too find the light you're looking for!! Bip Re: Lighting Shops & Pendant Lights - Perth 4Apr 16, 2010 7:33 pm Beacon lighting is where we got most of ours. They also do a trade account where if it isn't on sale, you get an extra discount (I think 5-10% can't remember). You can be any trade for it too, and they don't check if you are anything if you really want the discount. Unfortunately, we had very bad experiences at Tilly's with very very rude service. But we found what we wanted at Beacon in the end for 1/2 price. We got some lights from Lighting International too, they were good as well. Re: Lighting Shops & Pendant Lights - Perth 5Apr 17, 2010 10:19 pm Thanks guys for replying. Kexkez, we are East of Perth. RT Lighting is in Midland, extremely helpful and actually we've ended up buying just about everything from them. Thanks Bip and Mrs Smith too for your comments and suggestions. Still need to find some exterior lights suitable for salt air (we are building down south near coast). I'll try the other stores you mentioned. Brought my pendant lights today for over kitchen bench - ended up with chrome ones (I hope they will look okay - its hard to image until they are up isn't it!!) I wished I'd brought pendant lights first then brought other ones in the room to match, did it other way round then couldn't really match them to pendants I liked, so had to compromise! A big learning curve is building!!! If anyone has exterior lights (photos) suitable for coastal areas I'd love to hear. (Don't want the stainless steel tubular ones that just shoot light up and down, need a bit more wider light). Thanks Re: Lighting Shops & Pendant Lights - Perth 6Apr 17, 2010 11:21 pm SharonC Thanks guys for replying. Kexkez, we are East of Perth. RT Lighting is in Midland, extremely helpful and actually we've ended up buying just about everything from them. If anyone has exterior lights (photos) suitable for coastal areas I'd love to hear. (Don't want the stainless steel tubular ones that just shoot light up and down, need a bit more wider light). Thanks I'm just wondering why you would have to go to the expense of 316 SS if you are EAST of Perth? I thought they considered 'coastal' and the need for marine grade, etc to be within a couple of km's of the coast line? Maybe you could save a few dollars on the grade of SS if you check the recommendations? Oceanic with Nautilus upgrades. Handover 8 September 2010 Re: Lighting Shops & Pendant Lights - Perth 7Apr 17, 2010 11:57 pm (we are building down south near coast). They live east now. Built with New Generation (Summit Homes) We own land!... with a slab on it! Plus a shell of a house with stuff inside ! Re: Lighting Shops & Pendant Lights - Perth 8Apr 18, 2010 9:25 pm I've actually seen houses with downlights in the eaves and it looks fantastic. Projects a triangle of light onto the walls, and does light up the yard. Combined with some lights pointing up into some grass-like plants out the front it looks stunning. If you need to project light out sideways, the cheapest way is to get those lights that curve around and open out. Then it will focus the light away from the walls. (Sorry I can't remember what they are called!) Re: Lighting Shops & Pendant Lights - Perth 9Apr 28, 2010 3:10 pm We are getting our kitchen pendants from Alti on Stirling Hwy in Claremont... very nice pendants but quite pricey. Just down the road is Lighting Gales which is nice, big range and quite affordable. We're getting all our Oyster lights from Beacon but for feature lights you do get what you pay for I believe. Re: Lighting Shops & Pendant Lights - Perth 10Apr 28, 2010 10:14 pm Thanks for all your replies. We went to Tilly's , what a great shop! Ended up getting exterior lights called lancelot from Beacon lighting (had a special on) and pendant lights from RT Lighting at Midland. Never thought choosing lights would be so hard and time consuming! One more job ticked off the list!! Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28993 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9019 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8706 |
