Browse Forums Lighting + Lighting Design 1 Mar 14, 2010 12:54 pm Please help me choose a hallway light. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My flooring will be this http://www.utf.com.au/images/KEMPAS_1_STRIP_B_larg.jpg I am at a loss Thanks. What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8589 Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 51809 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61394 |
