Browse Forums Lighting + Lighting Design 1 Nov 23, 2009 3:02 pm This might seem obvious to others but I can't seem to get it When you are looking at pendant lights online and they say the 'height is 220cm' - does that mean from the tip of the lightshade to the fix in the roof, or does it mean height off the ground? 220cm height seems really long, is that too long for pendant lights over a kitchen island bench with 8.5ft ceilings? Dont want to be hitting my head!! this is what i'm looking at: http://www.buysterlighting.com.au/Cromp ... M1510.html Cheers Caz Caz & Co ALL MOVED IN!! Now comes all the hard work-decorating.... [b]Blog: http://cazoraz.blogspot.com/ Settling in Thread: viewtopic.php?f=31&t=36993 Re: Pendant light height question.... 2Nov 23, 2009 3:53 pm Hi cazoraz, I don't know if this is helpful or not but the electrician can usually adjust the lenght of the chain/wire to suit your needs, so when they are being installed you just decide then. We did that with our over bench pendants too. Hope this helps! Re: Pendant light height question.... 3Nov 26, 2009 9:25 am The shade itself is only 26cm high and 9cm wide. Draw it up on a piece of paper, cut it out and hold it up where you want to put it. As mentioned above, the actual 'wire' can be pulled through the roof to the height yo want. Re: Pendant light height question.... 4Nov 29, 2009 1:35 pm i 2nd that, the cable will definitely be able to be adjusted. you will probably have to cut it as it looks like quite a small ceiling plate, so make sure of the height you want. i'd recommended the bottom of the pendant hangs at 1.7 - 1.9m above floor level. Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10657 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7712 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9551 |
