Browse Forums Lighting + Lighting Design 1 Nov 04, 2009 11:53 am Our new house has a raked ceiling in the living/dining area and I was hoping to put in some pendant lights. The first will be over the lounge - approx. ceiling height 9.75' The 2nd will be over the dining - approx. ceiling height 13.25' I've seen a lot of the diagrams for pendant lights online have maximum length 1200mm. This will be too short for my pendants to be in line with each other, and in the dining room it would be too high to do any good anyway. I assume the maximum height would relate to the electrical cable length as well as the suspension chain/rod/cable length. Can an electrician rewire the lights and add longer chains? What are the options for high ceilings? Kylie Re: Ceiling too high for pendants? 3Nov 11, 2009 11:08 pm Hi Kylie. depending on the pendant lights you want to use, the manufacturer / supplier would quite often be able to supply additional cable and or chain for you to extend the pendants to your desired height. for pendants which are simply suspended by the electrical cable only, a reasonable electrician should not have too much difficulty extending the length to suit with a bit of cable from their local wholesaler. It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8284 I am trying to find lighting for kitchen, dining areas but looking online, I don’t know if there are specific details I should be looking at to make sure any lights I… 0 478 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39760 |
