Browse Forums Lighting + Lighting Design Re: Bathroom lights installation look right? 2Oct 23, 2009 7:14 am Im no expert, so not sure if they "should" be recessed, but I do think it would look much nicer. Sorry not much help. Building Thread viewtopic.php?f=31&t=13002 Site start: 8th July 2009 Handover: 11/12/2009! 5 months total build time. 40 sqs of luxuary...Bliss! Re: Bathroom lights installation look right? 3Oct 23, 2009 7:25 am Depends on the actual light fitting I think. If you look at the section you wanted to recess does it have breathing holes? (for the want of a better word) If it does I don't think it can be recessed. We had the same lights ready for our main ensuite but then decided to stick with downlights. But our light in the foyer also has a section that we initally thought would be recessed into the ceiling but on closer inspection it couldn't because of the air hole thingies. Some things are worth waiting for. Re: Bathroom lights installation look right? 4Nov 12, 2009 9:25 pm unfortunately a lot of these multi head spot fittings have oversized bases which as you can see are not well designed and not much thought goes into the aesthetics of the base. the base is not designed to be recessed into the ceiling and i think you will struggle to keep it in if you cut the ceiling for it to fit. I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17540 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5881 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10469 |
