Browse Forums Lighting + Lighting Design Re: Are LED downlights too white? 3Oct 06, 2009 12:51 am Hi there sco77k, LED's are available in a range of colour temperatures. The stark white you have seen, is what we call cool white, or even daylight. But, LED's are also availble in a warm white (orangy tinge), in addition to green, red and blue. Hope this helps. Re: Are LED downlights too white? 4Nov 12, 2009 9:15 pm yes, less lumens per watt and often the CRI levels are very low reducing the quality of lighting from these LED lamps ! Re: Are LED downlights too white? 5Feb 05, 2010 9:05 pm Probably already mentioned on the forum somewhere, but around 3000 is warm white (pinky), while around 6000 is cool white (bluey). When you have one of each in the same room, you can really notice it! It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8287 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5646 |
