Browse Forums Lighting + Lighting Design 1 Sep 14, 2009 1:12 pm I have just been made aware of the new regulations requiring 200mm space either side of downlights, therefore making downlights in wall niches a "no go" ....... There has to be other options available - I have included 5 wall niches in my house design and they all need lighting for full effect !! Any ideas..... ?....... or hopefully I have been misinformed !! Re: new regs for lights in wall niches ?? 2Sep 16, 2009 7:14 pm the clearances you quote are for installing non protected/hooded downlights. If you install downlights with a hood then you can use the manufacturers clearances. ie. Fireguard only require 25mm clearance. But dont just by any hood. The Wiring Rules require that, unless the protective hood is specially designed and certified by the manufacturer with specific installation instructions for use in close proximity to combustible materials, it must be installed with the default clearances - ie. 200mm. Hope that helps. Re: new regs for lights in wall niches ?? 3Sep 17, 2009 10:17 am Thanks ZX9 !!........... that makes sense and seems to have a simple solution too ....... Just would have been helpful for the lighting consultant to explain the solution last week...... I will call them - thanks for replying Re: new regs for lights in wall niches ?? 5Oct 06, 2009 1:14 am Hi there all, hoods come in a variety of sizes from 70mm all the way up to 90mm. Re: new regs for lights in wall niches ?? 6Feb 05, 2010 9:10 pm Keep in mind the wall thickness Another option is a CFL - no need to put a hood around those ones... I learnt the hard way about the hoods - I put some cheapy aluminium ones in my roof - as I was installing them I went back to the first one I did a few minutes prior, to find it was emitting more heat than just the uncovered globe on it's own. While the globe itself might be very very hot, the aluminium attracts the heat and slowly dissipates it. The cover was too hot to touch, and I wasn't game to leave the ceiling insulation as close as I had before, so moved it away again. As it was a no-name product (even though from a major electrical wholesaler) I doubt there would be any spec's on it (now that I've been reminded, I will try and track down some spec's). My solution for the wall cutout (servery) was to use a slimline under-cabinet 10w halogen. Perfect for leaving on for ambient light and trips to the kitchen to make the wife a cuppa... Only I'll be replacing it with a 4W LED soon (to save even more power, but from 10W down to 4W isn't much saving ). Re: new regs for lights in wall niches ?? 8Feb 14, 2010 8:35 pm EKT Would that just be for halogens?? The heat covers? Yes. Different spacing requirements are applicable to different types of globes. Someone posted an image from AS3000 in another thread, but I can't seem to be able to find it again... Re: new regs for lights in wall niches ?? 9Feb 17, 2010 2:28 pm Hi all,
have a look at the following link ... There you will find an image that will visually show all clearances required.
So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23025 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5197 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20235 |
