Browse Forums Lighting + Lighting Design 1 Sep 09, 2009 6:27 am I require a lighting plan that excludes the use of halogen downlights. Even though I love halogen downlights our energy requirements state that we need to use flurocescent or LED lighting. I have attached our house plans for you to review. Our ground floor has a ceiling height of 2.7m and the first floor is 2.4m. First floor - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ground floor - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Troy Re: I need a lighting plan - No Downlights 3Sep 09, 2009 3:15 pm ^^ as with what EKT said yes you can get Fluro downlights however you require more per room as the light emitted isn't as vibrant/bright etc. Re: I need a lighting plan - No Downlights 4Sep 11, 2009 10:44 am Agree with both comments. We have 80% energy eff ruling here in Qld. We are putting in over 30 downlights. 120mm dia brushed silver enclosure with a glass diffuser cover and they run a 15W CFL bulb. They look as nice or perhaps nicer than your std halogen. New one's at Beacon and run at about $31 each inc bulb Ozz Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com 6 55347 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28814 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8816 |
