Browse Forums Lighting + Lighting Design 1 Aug 29, 2009 8:05 pm Hi Can anyone tell me if it is possible to put downlights in the ground floor of an exisiting two storey house? Can you drill a hole through the beams in order to feed the wire from one light to the other? (We are doing our kitchen and will have a plasterer here anyway so they can patch if necessary). thanks heaps Re: Downlights in existing ground floor 2Aug 31, 2009 12:04 pm Liz521964 Hi Can anyone tell me if it is possible to put downlights in the ground floor of an exisiting two storey house? Can you drill a hole through the beams in order to feed the wire from one light to the other? (We are doing our kitchen and will have a plasterer here anyway so they can patch if necessary). thanks heaps Do you have an existing light fitting (batten) that you are replacing? If you do - then you could have a sparky 'tap' into that and add the transformers. Then the downlights that you require can be installed from underneath. So, I think it can be done asa a retro-fit/replacement. Re: Downlights in existing ground floor 3Aug 31, 2009 8:15 pm Hi JilaMint Yes there are 2 exisiting downlights in the room, but I want to move both of these and add more. I am assuming the beams for the floor above are running in such a way that to connect to the exisiting lights the wire would need to go through these beams rather than in the space between them. Does that make sense? Liz Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11759 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13663 |
