Browse Forums Lighting + Lighting Design 1 Aug 25, 2009 10:39 am We had intended to have one of those DIY oyster light fittings that have a movement sensor in them as our porch light. However when we went to get one ( bunnings) we were told that there had been a problem with them and so there had been a recall on them. not sure what brand they were. We had 2 at our last house for years without any problems so still would like to get one. Does anyone know of anywhere else to get one? Arlec do this one which is similar to what we had. ( metal rim where as we had a white plastic rim) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: External oyster sensor light for under the eaves 2Aug 29, 2009 8:50 pm well amazingly enough after 3 months of them being 'not available" even last weekend Bunnings have decided to restock the cheaper version that we had before. and after all this time Hubby has now decided he doesn't want it. oh well.. now it will be a more expensive sparky job to get an oyster light fitted later. grr i wanted a wall light but because hubby wanted these lights we got a ceiling fitting done. not happy jan. Re: External oyster sensor light for under the eaves 3Aug 29, 2009 11:50 pm kexkez well amazingly enough after 3 months of them being 'not available" even last weekend Bunnings have decided to restock the cheaper version that we had before. and after all this time Hubby has now decided he doesn't want it. oh well.. now it will be a more expensive sparky job to get an oyster light fitted later. grr i wanted a wall light but because hubby wanted these lights we got a ceiling fitting done. not happy jan. Get the sparky to install a separate sensor in place of your ceiling fitting and to wire in a new light point from that to your choice of position - now you have freedom, any light fitting. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 4624 I'm curious, did they provide any reason why they did not like the idea? 1 2613 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 3916 |
