Browse Forums Lighting + Lighting Design 1 Aug 11, 2009 8:29 am I didn't get much luck in the lighting section so thought I would try here....... I've just discovered that there are two voltage types of down lights! I had no idea So what's the main difference? Is one better than the other? One more cost effective/energy efficient? What does everyone recommend? I'll be having most inside (some in bathrooms and a few outdoors under the alfresco, front porch and garage/balcony eaves). ETA - we have planned our lighting around halogen globes not CFL globes. Didn't know if that was relevant or not! Thanks! Re: 12V or 240V Down lights?? 2Aug 11, 2009 3:03 pm Stay away from 12v ones. They use a transformer which can get very hot and don't be fooled by thinking 12v uses less power than 240v. 240v all the way. Then you can even use CFL bulbs in it if you like. Al & Caitie- Building the Hamilton 278 (Coral) at Narangba Re: 12V or 240V Down lights?? 4Aug 11, 2009 5:17 pm both ..depeding on the usage IMO 240V downlights in general areas that you don't want a light hanging down into the house... so hall ways and general purpose areas tho if you say are setting up reading lights above the bed then 12V downlights are awesome for that. or a feature wall 12V DL's have better beam angle choices.... I am going with this option as my partner tends to read in bed soem nights.. and a bright all room light or a ebd side lamp arn't good enough.... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23021 How long is a "long period"? For a few weeks, it should be ok. It also depends on the area you live in...I would let your neighbours know that you will be away too and… 1 28574 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12283 |
