Browse Forums Lighting + Lighting Design 1 Jul 27, 2009 11:06 am Hi guys, Can anyone give me a rough idea of what I should expect to pay to have light fittings installed? We're going to have all oysters, except for two feature pendants. Many thanks! G C&G -------------------------------- A new building chapter begins.. Re: Cost to install lights? 2Jul 27, 2009 12:05 pm We just had an electrician out to install about 26 different light fittings - majority were oyster lights, but we also had a tricky pendant light for the stairs and a number of drum pendants. All up was $600. Not sure if that is a good or bad price, it was the only quote we had but we were happy to pay that My karma ran over your dogma Re: Cost to install lights? 3Jul 27, 2009 12:06 pm haywgl We just had an electrician out to install about 26 different light fittings - majority were oyster lights, but we also had a tricky pendant light for the stairs and a number of drum pendants. All up was $600. Not sure if that is a good or bad price, it was the only quote we had but we were happy to pay that thanks for that! C&G -------------------------------- A new building chapter begins.. Re: Cost to install lights? 4Jul 27, 2009 12:38 pm Here's the 'extra's cost per item that I received from my sparky... Price is per item installed. Item Price Install Fan Light $95.00 Install Fans $85.00 Install Rattan 4 blade ceiling fans $125.00 Install Phone Points $55.00 Install 2 Way light switch $50.00 Install Light Points $45.00 Install light fittings supplied by owners $15.00 Install Chandelier style light fittings $50.00 Install Dimmer $50.00 Install sensor for lighting $45.00 Install Micro switch on Kitchen Pantry $60.00 Install Tastic Combos 2 heat lamps $85.00 Install Tastic Combos 4 heat lamps $125.00 Install Air Conditioning Large (elec only) $200.00 Install Air Conditioning Small (elec only) $150.00 Install Ducted air cond elec single phase $220.00 Install Ducted air cond elec 3 phase 20amp $300.00 Install Ducted air cond elec 3 phase 32 amp $350.00 Install Exhaust Fan/Light $75.00 Install Exhaust Fan $70.00 Install TV points $50.00 Install Foxtel Point $50.00 Install double power points $55.00 Install single power points $50.00 Install 15 amp Power Point and Circuit $150.00 Install Weather Proof Power point $90.00 Install end of Kitchen bench power points $95.00 Install smoke alarms $85.00 Install Tarrif 33 circuit for future pool $220.00 Install solar HWS circuit $120.00 Install extra power and light circuits $120.00 Install power circuit for power to Shed $250.00 Install HSTP power $55.00 Install u/g light/power in conduit/metre $12.00 Re: Cost to install lights? 5Jul 27, 2009 12:45 pm thanks cs-251 good post! 2014 - Prepping to build the Soho 4 with Plantation homes, industrial style 2009 - Built the Brampton with Coral Homes viewtopic.php?f=31&t=15399&start=280 Re: Cost to install lights? 6Jul 27, 2009 3:02 pm Very helpful post thanks Coral-Stradbroke251 gives us an idea of what to expect anyway. Cheers https://forum.homeone.com.au/viewtopic.php?f=31&t=19655 FINALLY slab down 5th SEPT Oct 16 Bricking/ plaster starting Dec 1 Painting started END OF CONTRACT IS UP SOON HURRY UP AND FINISH MY HOME..... countdown to 27th Feb. LATROBE 320 WITH DENNIS FAMILY HOMES That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8623 So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23012 7 11882 |
