Browse Forums Lighting + Lighting Design Re: No one did this before or is it toooo hard? 6Feb 23, 2009 11:53 am Our Entertainer - http://ausdreamhome.blogspot.com/ Re: No one did this before or is it toooo hard? 7Feb 26, 2009 11:48 am Our Entertainer - http://ausdreamhome.blogspot.com/ Re: No one did this before or is it toooo hard? 8Mar 01, 2009 7:25 am Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Re: No one did this before or is it toooo hard? 9Mar 01, 2009 7:38 pm Our Entertainer - http://ausdreamhome.blogspot.com/ Re: No one did this before or is it toooo hard? 10Mar 02, 2009 12:00 pm Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Re: No one did this before or is it toooo hard? 12Mar 02, 2009 12:20 pm John, Tarin and the Kids Built and moving in to the Regent Grande with Masterton homes http://thebrownsaremovingtothecountry.blogspot.com Re: No one did this before or is it toooo hard? 13Mar 03, 2009 1:24 pm Our Entertainer - http://ausdreamhome.blogspot.com/ Re: No one did this before or is it toooo hard? 14Mar 03, 2009 7:54 pm Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Re: No one did this before or is it toooo hard? 16Mar 04, 2009 5:15 pm Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Re: 17Apr 27, 2009 11:53 am satskape Re-opening this thread... Can we install the regular blue deck lights on the sides of driveway? Obviously they cannot be driven on. If yes, what should be done prior to getting the concrete laid and how to install these afterwards. I think there should be some sort of piping installed in ground and into concrete prior as I don't want these lights to be set directly into concrete while pouring. Is it good to go with 12V or 240V? Any advice please? MICA Team? Yes lights like these can be retrofitted after the concrete has been poured. All you need to do is buy the appropriate size core drill (or call concrete cutter and driller) and drill through your concrete until you reach the soil beneath, then from the sides you just dig under till you reach your hole, dig trenches for your conduit and then glue and lay conduit into trench's TIP:(as you put conduit together feed a draw wire/string through it make life very easy when pulling/feeding cables through). If your using low voltage 12v stuff it's all DIY, as all the wiring plugs into a transformer (12v-240v) and plugs into an external GPO. Another option you can buy and install aswell is a photo electric cell (pec) that will turn the lights on and off when its night and day ($16.00 approx) I do these kind of DIY installs all the time into decks, concrete, brick walls, sleeper retaining wallls etc I'm not an electrician (i'm a builder) but this stuf is really easy to do. Ben BUILDERSEDGE PTY LTD LEADING THE WAY IN BUILDING AND CONSTRUCTION BUILDERSEDGE PTY LTD 5 10476 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11584 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17047 |
