Browse Forums Lighting + Lighting Design 1 Jul 22, 2009 2:32 pm Hi all, I was wondering what cost I should expect for a sparky to run cables, install downlights, and then install switches ? My builder is charging a lot for it, hence I'm looking for a 3rd party to do that for us instead. Cheers Edited: I will be installing nearly 60 downlights.. Re: Cost to install downlights, run cables, and install switches 3Jul 25, 2009 11:02 pm Hi there all, An electrician should be charging approximately $40 per connection point. This includes all wiring and switches. Obviously this depends on the size of the job. When installing 5 downlights, the price will definately vary when installing 50 downlights. Then you need to add the price of the fitting that you choose. Hope this helps. 7 6251 Shelly switches require a paid subscription for full access to all features which is ridiulous given the lifespan of a home and if you were to sell it or buy a home with… 2 4527 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7541 |
