Browse Forums Lighting + Lighting Design 1 Jul 19, 2009 11:28 am Does anybody have any good ideas about where to find a large range of pendant lighting options for lounge & dining? I have exhausted Rovert & Beacon? Not having much luck online so far... maybe too fussy? I'm in Newcastle but can get to Sydney. Re: Retail lighting options 4Jul 25, 2009 11:48 pm Hi there, There are so many varieties of pendant lighting. have a look at the following links: - Pendants and chandeliers - http://shop.micaunited.com.au/cat/2016674.html - Solid Brass Pendants - http://shop.micaunited.com.au/cat/2057588.html Hope this helps. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8812 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8570 |
