Browse Forums Lighting + Lighting Design 1 Jul 16, 2009 9:16 am Hi, We are doing an extension and would like some advice about how many downlights we will need in our new room. The new room is 7m x 5 m and it comes off the kitchen. Here is an image (new room labelled FAMILY) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We were thinking 8 and having them on 2 switches - the four in the middle, and the four on the outside. What do you think? Thanks Andrea Re: Help with lighting plan 2Jul 26, 2009 12:56 am Hello there Andrea, The setout you have opted is perfect. Keep it simple, and useable. Good work! Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 22131 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 5613 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 5877 |
