Browse Forums Lighting + Lighting Design Re: electrical/lighting plan help! 21Jul 26, 2009 12:12 am Hi all, Under cupboard lights are so simple to install, and have that simple but extrodinary effect. There are 2 ways to instal them: 1- Have a false concelled compartment within the base of the overhead cupboard. 2- if you opt for the 240v ones, then all you need to do is hardwire and chase the wire through the base of the overhead cupboard. Run this by your electrician, but they are the simplest things to instal at the building stage .... otherwise, they are a nightmare (and maybe impossible) latter down the track. Hope this helps. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28819 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8820 |
