Browse Forums Lighting + Lighting Design Re: How much per light fitting? 2Jul 07, 2009 8:06 am Judie, Not sure where you are getting your fittings from. I am getting these from a shop in Castle Hill. The lady from the shop is visiting our under construction home this week. She will quote on the fitting charges. Once I know will let you know. Have you decided on the fittings and also, where you getting them from? Re: How much per light fitting? 3Jul 07, 2009 10:15 am Judie We are having our light fittings installed after handover. What's the going rate per light for this? Judie Our sales lady suggested we buy our fittings from wherever & pay their sparky $20 per light to fit them. Dont know if that helps you any? Cheers Kim Re: How much per light fitting? 4Jul 07, 2009 10:19 am $15 per light to fit anything - downlight, chandalier, external light whatever... I knocked the GST off too so $13.50. That's direct to the electrician. Al & Caitie- Building the Hamilton 278 (Coral) at Narangba Re: How much per light fitting? 5Jul 07, 2009 10:37 am alk $15 per light to fit anything - downlight, chandalier, external light whatever... I knocked the GST off too so $13.50. That's direct to the electrician. which area are you in? We were told around $50 per light - in Sydney!! progress viewtopic.php?f=31&t=20401 sculptures viewtopic.php?f=36&t=26607 pole trouble viewtopic.php?f=3&t=25988 Re: How much per light fitting? 6Jul 07, 2009 10:44 am seeking solutions alk $15 per light to fit anything - downlight, chandalier, external light whatever... I knocked the GST off too so $13.50. That's direct to the electrician. which area are you in? We were told around $50 per light - in Sydney!! Brisbane. Keep in mind, fitting = just attaching the light to the ceiling and plugging it in the light point. To wire up a light point, $41 but I got it for $36.90 (41 of em). Al & Caitie- Building the Hamilton 278 (Coral) at Narangba Re: How much per light fitting? 7Jul 07, 2009 10:54 am When we built this one the electrician charged $10 a time to fit a batton fix or oyster. Think it may have been a little bit more if we had gone for pendants. The light fittings themselves ranged from $20 to $100 each Know where your going in life............... you may already be there 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11696 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17361 |
