Browse Forums Lighting + Lighting Design 1 Jun 14, 2009 9:57 pm What lighting do you have, or plan to have in your media room? I was originally thinking downlights, but now considering wall lights? Anyone have pros/cons? Love Kristi Living the dream. 4 horsey acres in the country. What's the next project??? Re: Lighting in media room 2Jun 14, 2009 10:00 pm I'm having both downlights and wall lights in the theatre. I think the theatre is one room where multiple lighting options are a good idea. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Lighting in media room 4Jun 14, 2009 10:10 pm Ooo.. I didn't even consider having both What sort of wall lighting did you get? Are the downlights dimmable too? Love Kristi Living the dream. 4 horsey acres in the country. What's the next project??? Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28814 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8815 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8572 |
