Browse Forums Lighting + Lighting Design 1 Jun 06, 2009 1:11 am hi there i was looking at the lightica website when I came across some PLC downlights. How are these different to CFL? Is one better than the other? cheers about to build our first home! Re: what's a PLC light? 3Jun 07, 2009 4:40 pm thanks. do you think it will beeasy to get replacement lamps? about to build our first home! Re: what's a PLC light? 4Jun 07, 2009 5:59 pm Hmm - It's new technology they are promoting and if it gets legs and takes off ie lots of installation - yes - if not - no. Personally - what the reasons your considering it? Other than the sparky promoting it. Re: what's a PLC light? 5Jun 08, 2009 1:00 am hi there Only considering it as some of the downlight's that I've seen on the net use PLC lamps. Basically I was looking for a CFL downlight with a highish wattage as we're going to have quite high seilings and I was worried that they might not be bright enough. I saw some downlights that take PLC lamps that have two globes in them. We don't need them for another 6 months or so, so I guess I should watch and wait for now? about to build our first home! Re: what's a PLC light? 6Jun 08, 2009 8:57 am The PLC lamps are better, but you need to have the right light fitting. The benefit is that the ballast is part of the light fitting, so it's not replaced. The lamps should be cheaper. Demolition August 2009, Construction Started September 2009, Completed December 2010 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11708 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17375 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 19991 |
