Browse Forums Lighting + Lighting Design 1 Jun 02, 2009 9:57 pm Hi, As our construction is due to begin any day, we received a letter with Clipsal brochure from the electrician, introducing themselves. Apparently, you go straight to them for any upgrades etc..In the letter it says : we strongly recommend that you contact a lighting supplier to design your lighting requirements and specify the types of light fttings and switch positions that will be installed." I am new to all this and have no idea what to do as we have bought all our lights from shops here and there when they had specials on.. so who is our lighting supplier? We need to call electrician up and ask if we can't send them a list of our additional requirements (not very long) with a home made diagram... anyone else had that? Building the 22sq Ashton Re: Sparky wants a lighting supplier to design lighting reqmts. 2Jul 26, 2009 12:46 am Hi there Joile, I haven't heard of that one before, but it may be because you have already purchased your light fittings. Nonetheless, if you still require some help, feel free to contact us. Happy to help. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28761 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8768 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8506 |
