Browse Forums Lighting + Lighting Design 1 May 17, 2009 3:24 pm Wondering about batten fix lights in the bathroom - after a bit of research cannot seem to find if this is an appropriate type of light fitting in a bathroom re moisture - opinions/experience appreciated..... Re: Batten fix lights in bathroom 2May 17, 2009 4:39 pm With a proper exhaust fan I'm not sure you'd need any special light fittings in a bathroom itself. Above the shower yes - but other areas should be OK as the moisture would be removed by the fan. Re: Batten fix lights in bathroom 3May 17, 2009 4:58 pm Thanks yak chat - found a topic - vanity light post by installation inspector that gives details - like you said as long as not above shower or bath and 600mm from shower edge (unless the fitting is approved for such use) - thanks for replying - so hopefully going with batten fixes in bathroom. I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10030 Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5142 DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 5967 |
