Not about lighting but....
If I run a 75m extension lead from my temporary power pole to my shed, is there going to be any loss of power along this distance?
Thanks
JB
Browse Forums Lighting + Lighting Design 1 May 04, 2009 6:30 pm Not about lighting but.... If I run a 75m extension lead from my temporary power pole to my shed, is there going to be any loss of power along this distance? Thanks JB Re: Question for an electrician or electrical expert 2May 04, 2009 6:37 pm James Bond Not about lighting but.... If I run a 75m extension lead from my temporary power pole to my shed, is there going to be any loss of power along this distance? Thanks JB A little, but I ran our factory like that for the 4 months it took to get power... same distance. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Question for an electrician or electrical expert 3May 04, 2009 6:51 pm ed @ EcoClassic James Bond Not about lighting but.... If I run a 75m extension lead from my temporary power pole to my shed, is there going to be any loss of power along this distance? Thanks JB A little, but I ran our factory like that for the 4 months it took to get power... same distance. Ed Thanks for the response Ed JB Re: Question for an electrician or electrical expert 4May 08, 2009 6:25 am It all depends on voltage drop. Usually most extension leads use 1.5mm2 cable and are no longer than 30 metres long. Your best bet is to talk to an electrician and get them too calculate your load and give you an idea of cable size. You may have to use a 4mm2 or 6mm2 cable to do the job. Re: Question for an electrician or electrical expert 5May 08, 2009 7:10 am It really depends on what load you are running at the end of the 75m... To give you a example.... If it is 1.5mm2 Cable... And you are drawing the full 10A... Then you would see around 25 Volts lost to the cable.... So instead of getting 240V, you'd have 215V... If its 2.5mm2 Heavy Duty Extension lead this reduces down to around 14 Volts.... Again this is at the full 10A loading... If it's only 5A, then halve these numbers.... Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: Question for an electrician or electrical expert 7May 08, 2009 9:05 am borg you will always get a voltage drop. The question like people have mentioned above is what do you plan on running. If you are running high current devices like a compressor this will be an issue. I was planning on running a laptop, a kettle occasionally and small power tools eg drill, electric saw. And a light or 2. Probably not all at once. Cheers JB Re: Question for an electrician or electrical expert 8May 08, 2009 9:29 am James Bond borg you will always get a voltage drop. The question like people have mentioned above is what do you plan on running. If you are running high current devices like a compressor this will be an issue.[/ I was planning on running a laptop, a kettle occasionally and small power tools eg drill, electric saw. And a light or 2. Probably not all at once. Cheers JB We ran all of that and more (including a small compressor)... try it out, you can do that now. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Question for an electrician or electrical expert 10May 08, 2009 12:11 pm borg I guess it depends on the compressor. I ran a 15cfm one over one 20m lead, and it was struggling. Changed over to a thicker (Home made lead) and it was fine. You could ask an electrician to wire multiple el cheapo leads in parallel. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 0 1347 Must be labour only. One of those how long is a piece of wire questions. 4 4097 |
