Browse Forums Lighting + Lighting Design 1 Mar 03, 2009 2:28 pm the full story can be seen here
http://www.environment.gov.au/settlemen ... index.html In short this is a heads up when choosing Lighting. Choose wise and think future proof in terms of the lamps used now and what the alternate will be later on. Both in terms of cost and looks. As someone who works in the industry, it is now getting harder to source standard GLS (normal) globes.Yes they are still around but won't be much longer. Cost on energy efficient replacements are still on the high side but hopefully will come down in time. Electrical Wholesaler Re: Lighting - PHASE-OUT OF INEFFICIENT INCANDESCENT LAMPS 2Mar 03, 2009 9:16 pm in queensland we have the smart climate service from the govt, they will provide 15 energy saving bulbs in the service which costs $50, plus they throw in a shower head, a energy use meter and check everything out, be mad not to jump at that if your in qld and have a house that isnt brand new or has quite a few old type bulbs Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. 1 62023 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28814 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8817 |
