Browse Forums Lighting + Lighting Design 1 Feb 16, 2009 10:54 am In my last two places, I have installed Crompton LFD style lights.
They are linkable as they either plug into each other or use a small extension cable. They come with all the hardware and just plug into a power point. I use them under cupboards to light up benches instead of downlights. They are a plug'n'play style but I actually wire them back to the light switch, or a switch on a power point. I have also wired them into the range hood so when you turn the light on the range, all these come on. I have also put them in walk in wardrobes under the shelf. If you want to hard wire them, get a sparky to do it! don't just think you can wire it in anywhere there's power! http://www.cromptonlighting.com/cat07/s ... &subcat=10 Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Re: Bench light alternatives. 3Feb 18, 2009 6:36 am Nothing that looks good without being hidden by a pelmet.
I have seen LED strip lights but were quite expensive and not producing as much light. The typical downlight but that requires a fair bit of work to make them look anygood. I like these as they come in different lengths (and wattage). I've also used them in bars. One customer wanted a wet bar in his boardroom. He actually just watches sport in there so it became a theatre for him. These lights worked well as they didn't light up the room but just the bar bench area. Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Slimline Linkable t5 4Mar 03, 2009 12:17 am Hey there Guys,
I must admit, the linkable slimline t5's are great. Especially that they come in many sizes. we have just released the 35w fitting. Take a look - http://shop.micaunited.com.au/details/2559484.html Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11696 11 23161 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31266 |
