Browse Forums Lighting + Lighting Design 1 Feb 06, 2009 8:46 pm Question for those electrically inclined - we are looking to build a deck in our little side area that measures 7X4 metres. The deck will go all the way from the door to the fence on each side. There will also be minimal clearance underneath the deck. I want to install recessed deck lights, my dh is telling me this is not possible due to the lack of access there will be to underneath the deck. Is he telling me a fib? Re: Recessed deck lighting 3Feb 07, 2009 9:33 am FIBBER!!!!
Recessed lights are only 50-75mm deep... They will fit in ANY decking just fine Re: Recessed deck lighting 4Feb 08, 2009 9:32 am Sorry having computer problems
It should be possible. I have seen them recessed into pavers and concrete so don't see why you couldn't put it into decking. If you have a nice sand or dirt bed underneath to run the cable in it will be easier. The only problem you may have is where to mount the transformer, if lots of lights, bigger transformer, bigger cable. As long as they are lv ones it should be ok these ones look good http://www.lightscapes.com.au/paver_lights/ http://www.onlinelighting.com.au/produc ... ts_id=3694 heaps to look at here that aren't very deep http://www.onlinelighting.com.au/index.php?cPath=60_130 Just check the IP rating on the lights, if you are going to get some, ensure that they will be ok with a hosing OH might be thinking down the track if you get cable damage or something. might be a pain to fix Deck Lighting 5Mar 03, 2009 12:36 am Hi there Sheree,
Where did you find this fibber?? These days, there are so many lighting options, that i haven't come across this situation. Have a look at this - http://shop.micaunited.com.au/cat/2017502.html?page=1 Hope this helps. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29190 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9189 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8878 |
