Browse Forums Lighting + Lighting Design 1 Nov 12, 2008 12:13 pm Hi all
I'm just about to get my paving done, so I'm going to run some 12V cabling underneath so I can put some bollards in there later. (This is for a driveway) I have a 45m run with 10 lights, so I was thinking a 220VA transformer, and have two runs (5 lights on each run) with heavy duty cable so there's not too much voltage drop over the distance. I want to install a motion sensor at the other end (ie. opposite end to the transformer). Has anyone seen anything that'll work (ie. waterproof and 12V)? Also, any other comments about my proposal would be great. Thanks Re: Garden Light Gurus 2Jan 02, 2009 1:28 pm Maisie I want to install a motion sensor at the other end (ie. opposite end to the transformer). Has anyone seen anything that'll work (ie. waterproof and 12V)? Aquatran make a 12V outdoor motion sensor: Aquatran Motion Sensor timer switch 240V - Wall mount - AQT-003 weatherproof transformer 3Mar 03, 2009 12:45 am Hi there Maisie,
you may be looking for something like this - http://shop.micaunited.com.au/details/2204457.html Hope this helps. Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11709 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17379 It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 19992 |
