Browse Forums Lighting + Lighting Design 1 Sep 01, 2023 9:59 pm Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters in length and weighing approximately 25 kilograms. Unfortunately, I'm not satisfied with its current position and would like to shift it about a foot or two from its current location. The chandelier is mounted on the ceiling above a void, so I assume that to remove it, it would require some sort of scaffolding or special equipment. My main concern is how challenging this task might be after the house has already been constructed. Any insights, advice, or tips on how to go about relocating such a hefty chandelier would be greatly appreciated. Thanks in advance! Struggling to find a chandelier with LED globe replaceable without any LED diver for my U-shaped staircase. Please share details if you bought similar to… 0 1049 In kitchen design, want to run the full recessed LED channel under overhead cabin including the undermount rangehood (BOASH Series8 - 282mm deep). cabinet guy said the… 0 319 You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 19159 |
