Browse Forums Lighting + Lighting Design 1 Aug 27, 2021 11:49 am Hi guys, I'm wanting to install a smart thermostat in place of two old existing controllers. To also open up the available wall space, I want to relocate the thermostat to an area above the light switch. Please see below image. Is it safe to move the wiring of the thermostat to be inline and above the switch? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Relocating thermostat above light switch 2Aug 28, 2021 9:14 am basKT_case Is it safe to move the wiring of the thermostat to be inline and above the switch? Depends on where the light switch cabling is and how careful you are. Have you found a suitable smart thermostat? Re: Relocating thermostat above light switch 3Aug 28, 2021 9:24 am arcadelt basKT_case Is it safe to move the wiring of the thermostat to be inline and above the switch? Depends on where the light switch cabling is and how careful you are. Have you found a suitable smart thermostat? Is that something a stud finder with live wire detection will tell me? I am interested in a Nest Thermostat to combine both heating and cooling controllers into one device. Though i understand i will lose the variable fan control of the evap cooler. Re: Relocating thermostat above light switch 4Aug 28, 2021 9:30 am basKT_case Is that something a stud finder with live wire detection will tell me? Should do, but turn the power off anyway when you are drilling/cutting in that area. basKT_case I am interested in a Nest Thermostat to combine both heating and cooling controllers into one device. Though i understand i will lose the variable fan control of the evap cooler. You should do significant research on that. Nest Thermostats are not available in Australia and not official supported for a good reason. While many of us have made them work, you’ll need to determine compatibility with your Brivis system. It may be that you will need to install an intermediate relay system. Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1234 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20619 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11763 |
