Browse Forums Lighting + Lighting Design 1 Oct 07, 2008 3:41 pm I went to replace a light today and noticed that the light (20 years old), had 4 terminals into which 9 wires went.
two wires, active and netural are the power source, whilst 2 sets of Act,Neutral,Earth are wired to carry to to another light (god knows why a splitter box wasn't used), and a final black line which I assume is the switch line. What I am not clear on is why the active from the forwarded power lines goes into the fourth terminal on the light fitting. What are there four terminals? Active. Neutral,Earth and what?? Re: Electrical Lighting Issue 3Oct 15, 2008 7:57 pm Dave is correct. It's just a handy spare terminal not connected to anything, to use instead of using a BP connector. And don't do what someone I knew did many years ago - disconnect and separate ALL the wires at once, then put all the black wires back together (and he wondered why the rest of the lights in the house were only half as bright as normal ). The scary thing is he was an apprecntice electrician... Better still, get a licenced electrician to connect it up for you. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28990 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9014 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8699 |
