Browse Forums Lighting + Lighting Design 1 Sep 18, 2020 9:16 am Friends, Just moved into a house which requires sensor lights.in entrance, the block is 25m wide and has neighbour on either side. I am not sure what lights I would need and where ? I am considering the following 1. a single flood light above the garage and 2. a double light on the right corner of the house ? Added an image of the house , please advise . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Confused with sensor security lights 3Sep 18, 2020 10:43 am ![]() Friends, Just moved into a house which requires sensor lights.in entrance, the block is 25m wide and has neighbour on either side. I am not sure what lights I would need and where ? I am considering the following 1. a single flood light above the garage and 2. a double light on the right corner of the house ? Added an image of the house , please advise . Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Mr. Beams battery powered sensor lights? Buy say 4 of them and you can move them around until you get what you feel is ideal coverage. Powered by standard D cell batteries that last +6 months in service. Re: Confused with sensor security lights 4Sep 18, 2020 11:29 am ![]() ![]() ...please advise. Can you explain why you think you need sensor lights? There might be better options these days. Also, could you say what you budget is? We wanted few lights to glow up when some one is at the door or when there is movement in the entrance ? I am open to solar or even Battery operated lights as well. Also I want to minimise bringing in an electrician who use going to charge me a bomb for $50 light Re: Confused with sensor security lights 5Sep 19, 2020 2:44 pm ![]() ![]() ![]() ...please advise. Can you explain why you think you need sensor lights? There might be better options these days. Also, could you say what you budget is? We wanted few lights to glow up when some one is at the door or when there is movement in the entrance ? I am open to solar or even Battery operated lights as well. Also I want to minimise bringing in an electrician who use going to charge me a bomb for $50 light https://www.amazon.com.au/Mr-Beams-MB390-300-Lumen-Weatherproof/dp/B00BCCNZA2/ref=asc_df_B00BCCNZA2/?tag=bingshopdesk-22&linkCode=df0&hvadid=&hvpos=&hvnetw=o&hvrand=&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=&hvtargid=pla-4583520391129186&psc=1 Hi all, I've installed a mixed sensor tap (for a basin), where the hot and cold combine and in theory should output warm water through one one flexible hose (it was… 0 402 Hello everyone I'm a long time lurker first time poster! 0 1125 ![]() 5 1637 |
