Browse Forums Lighting + Lighting Design Re: Downlight options - going as eco as possible 16Jan 10, 2009 11:23 am A 15W CFL should give about the same light output as a 50W halogen (or 35W IRC halogen. By CFL I mean one of those lights that is roughly the size of a normal lightbulb.
The problem comes with the GU10 CFL that are the same size as downlights. Due to the very small size you just don't get the efficiency needed. So you end up needing, as chuth mentioned, three times as many lights. If you want the best energy efficient option available today, nothing beats a 15W CFL in a larger than GU10 size. These are one-for-one replacement for halogen downlights. That is, you'll need one for every 4 square metres of floor space (4 for a 4 x 4 m room). Demolition August 2009, Construction Started September 2009, Completed December 2010 You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 37174 0 12266 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 5028 |
