Browse Forums Lighting + Lighting Design Re: Lighting resources for industrial/vintage/quirky styles 2Feb 12, 2013 6:58 pm Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Lighting resources for industrial/vintage/quirky styles 6Apr 03, 2013 11:33 pm You're welcome! Just had another browse of about space tonight. Oh my gosh I've got a wish list as long as my arm! Lol HD Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29180 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9181 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8872 |
